RW 6 sites in RW 7.5
Will a site created in RW 6 fully open in 7.5 and function properly? I would like to transfer a file made in 6 to 7.5 but I am hesitating until I know for certain it will work and I will note lose everything.
Make sure any plug-in’s/ stacks etc. that you have in RW6 are working in RW7.5
Make a duplicate of the RW6 project in case of issues
Open the RW6 Project in RW 7.X
Everything should be fine.
Thanks Scott. Yes, all plug ins work fine in 7.5 and I have backed up every file that would be used in 7.5. Will give this a try now.
