Can't open saved v5.4.1 project in v7
A couple of months ago, I purchased the v7 upgrade, however I have never been able to open my existing website created in v5.4.1 using v7. I posted this on the forum then with no responses and also noticed another person who had the same problem with no resolution. Rapid weaver support was VERY POOR.
Any help is appreciate!
Hi Keith!
Had you sent a mail to RW Support? support@realmacsoftware.com to open a support ticket?
@dan
Typically, RMS has excellent support.
Cheers
Jürgen
I’ve sent them a support ticket, over the past 2 months I’ve gotten no where, responses are anywhere from 3 days to 4 weeks apart, terrible!
I’m pretty sure you have to first open it 6.3-4 , say it and open that one in 7
The final version of 5 (I think it was 5.4?) had an “Export project for RW6” function. So you need to “export” from 5.4 to 6.x and then open the RW6 file in 7. I think that’s what you need to do… not guaranteed!
