RW 7.5.5 and Force Quit
I’m facing an annoying issue with 7.5.5 and the SFTP uploader. If I do not put anything in the passphrase for the SFTP upload setup, then uploading my site will cause RW to lock up at the uploading window. I literally have to force quit the app and restart. If I type ANYTHING in the passphrase field, the upload works, but then the field is empty upon restarting RW the next time.
Has anyone seen this behavior?
Running high Sierra? Might check this post out:
