After transitioning my webhosting to PHP7, new blogposts have stopped appearing on the web. Export from my RW8 goes, everything looks fine, but the new blogpost will not show up on the web. Any tips or ideas? Note that I am in this complete layman and I do not even know what PHP is.
Thank you very much and sorry for terrible English.
I don’t use the built-in blog but a few things to check… It seems like (based on the browser inspector) that you’re using Strata version 1.0.7 The newest version is 1.3.5 It’s probably worth upgrading your theme in case there are compatibility issues.
If this were an issue because of a PHP update, then most likely the page would be blank. When PHP encounters an error, it stop parsing the page/html immediately.
I do see some errors in the console that you may want to ask @nickcates about
Yep, update for sure. Go to https://nickcatesdesign.com and click on Find Order. Enter your Strata purchase email address, and click Find Order again, you should be able to download Strata from there
