when I launch RW8 I get a pane noting that some upgrades did not load. I click that and then I get another pane noting that RW ‘unexpectedly quit’ and round and round I go until it finally loads.
My version of Stacks 4 is paid for, so that is not the issue.
Those “Not codesigned messages” are usally because you upgradedg macOS 10.15.x or greater. Apple desided to protect you from stuff that has been running for years.
Big Sur won’t help! Apple is locking things more with each update
You need to upgrade all plugins to the latest version. If they are older ones, they won’t work. If they are no longer supported, you will need to delete them.
You can get the latest version of sitemap from the yourhead site (same as stacks)
You can also quite RW and the start it will holding the ⌥Opt key.
You should get a screen that allows you to start RW without 3rd party plugins. That will allow you to getin and find what plugins you have installed and remove them (if you aren’t using them) or find updates for them.
This was more an Apple thing, with Catalina they started locking things up.
@chicago Hopefully @teefers suggestions will help. (I have no idea what’s happening to you, unfortunately). I’m tagging @isaiah : since he is the developer for Stacks and Sitemap he might have some extra suggestions that will help you out of this quagmire.
The error messages you posted indicates an issue with SiteMap, as Doug (@teefers ) pointed out. You need to update that plugin. Like Stacks, it’s also made by YourHead Software. You need to download and install the latest version of that plugin. Have you done that?
