My blog archive only displays the dates which I find useless, the title would be preferred.
Finding a subject that was blogged is very difficult opening each and every posted date.
Is there a work around.
Thanks.
Would using Categories and Tags help at all?
Rob
As Rob says ![]()
I do not use this stack, but it sounds like it could be an option for you if you don’t find categories and Tags a sufficient answer.
Live Search By 1LD
There may be other similar options.
But it also adds another level of perhaps unnecessary complexity…
Perhaps a blog is not the best format for organizing your information?
Sorry but I’m not familiar with Categories and Tags. And will search.
I read somewhere that the RW blog page does not work with Stacks.
But I believe the builder could make a change to have the titles along with the dates showing.
Thanks Rob and Chuck
The Blog is a page type on its own and isn’t designed to work with Stacks.
If you have Stacks you could always look at the excellent Poster stack from Instacks. That’s a great blogging solution.
Alternatively, you can turn on Categories and Tags in the standard blog page and then add those to your blog posts as a way of organising things. Here’s a blog that uses both.
HTH
Rob
Thanks a lot Rob, I’ll give it a try.
You are absolutely correct, the Poster stack worked perfectly. I’m in the process of transferring the earlier posts over.
Thank you Rob.
