I just did a publish today and was notified I had multiple index files.
I set rapid weaver to publish all in php and I found an Index html file. Would that be the cause and can I delete it?
RapidWeaver just warns you, it’s up to you to determine what one is correct and delete the other. Since you’ve set up everything to be PHP then you should be able to delete the html version.
