Hello, I discovered last month that my website slideshow pages created with RW’s photo album page no longer display properly on any iphone. I assume this is due to updated iOS, as it still looks perfect on iPads or desktop displays. Since my site was created with RW6 and Photographos VI v1, I updated both to the most recent versions (RW8).
I had to do some tweaking since the software has changed a bit, but when I use the built in simulator on RW the slideshow images are severely cropped, so the entire image cannot be seen. If I change the album type to Gallery instead of Slideshow, the images display properly. I have tweaked every single option available to no avail.
I assumed this must be a theme specific problem, but when I view the slideshow pages using different themes, I get the same result. Has anyone else had this problem, and found a solution? Could it just be a problem with the simulator? I’m not sure how to upload just a test page to check.
Thanks for your help!
Tim
www.timandrews.com (not yet updated)
