After launching RW 8 and opening an existing project, I get the stacks library, but furthermore only a blanc space, in stead of the edit or the preview mode. Only clicking on edit mode or preview mode will reveal the project I asked for. Not a big deal, but I think it is strange. Not the way RW 8 should start. Anyone an idea?
You likely saved your project file while in Preview Mode. RW restarts in the mode you were using last — Edit or Preview. I find sometimes the page will display blank if the app opens a project that was saved last during Preview Mode. I can’t readily repeat it but maybe it is something you can recreate regularly. If so you might get with @dan and @isaiah and see if they can assist in hunting down the bug.
I see this quite often as well and try to avoid saving in preview mode. Otherwise, as you say, switching between modes and sometimes pages kick starts it again.
Thanks Adam and Greg! After a few times testing, RW indeed started in the edit mode, when I saved RW the last time with the edit mode on screen. Something to remind every time.
Case closed, I think!
