RW/Writer Blog Problems
Are there any users of the RW/Writer Stacks, that are now supported by Yuzoolthemes, having problems?
I have a number of client websites that I’ve added the stacks to in order to create a ‘our news page’ or ‘job vacancy page’ etc that the client can easily update through the RW/Writer admin panel.
At some point over the last week the blogs stopped publishing the latest posts. Although everything appears fine in the RW/Writer admin panel and you can add/edit a post, the websites with the RW/Writer stacks are not being updated. On one site it is publishing posts that have been deleted a while ago.
If anyone out there is using RW/Writer it might be an idea to check if your sites are working or not. I have posted a support ticket to Michael and I’m waiting for a response.
Thanks @shw - there’s no problems that I’m aware of and our test blogs are running fine.
Can you clear your browser cache and let me know if there’s anything still not running well?
:slight_smile:
Everything is back up and running now. Thanks for fixing the issue Michael.
