Can’t download rw5 to I pad mini intend to upgrade to 7 later but need Rw on my I pad mini
It won’t install on an iPad, Gary
No MacOS program will work on iPad’s or iPhone’s and visa versa.
…which means that you can only install apps that were made specifically for iOS.
Hi Rob
So website design I pad crap then.
You’ve not got enough screen, really - there are a few products, but they’ll force you into one or two layouts and everything will end up looking the same. I guess you could hand-code…
Also would have no access to any of your third party plugins, stacks etc.
hi @Gazzer , why not try with “easy cms” or t
“total cms”? design it on your mac design all the changes on the fly on your ipad.
just sayin’, tomas
