Hi - I have been waiting for an easy way to do this and RW7 promises it, yes after upgrade I cant seem to find any reference to it in the manual? or anywhere else. Does anyone know how i move a project from one mac to another? Cheers
Hey @manju69,
For your projects, please check this out: http://rapidweavercommunity.com/tutorials/series/new-features-in-rapidweaver-7/episode/portable-documents
And for your addons: http://rapidweavercommunity.com/tutorials/series/new-features-in-rapidweaver-7/episode/user-selectable-addons-folder
Hope that helps,
—E
ElliotEKJ
These links don’t work for some reason…?
Argh, my mistake. Sorry about that, have fixed them.
—E
thanks - i had an issue with moving addons as the video described. I moved them - re opened project and the site no longer found them? (they showed up as outlines in the add ons manager and some of the stacks no longer worked, so I went back to RW managing them and sit all worked fine. What am i doing wrong?
I have all my add ons in my dropbox along with the project files. I then pointed my macbook pro and iMac to these. You do have to wait a bit for Dropbox to update that is key. I found that Dropbox is not autoloading on the iMac so the updates did not get through. This was expected
What i mean was even before moving them between macs - just to another local folder to test it - this rendered the errors listed above when opening the project
