I’m using the above theme and am having text and image placement / formating issues. Tried contacting the developer but issues have not been resolved.
None of the text formating works.
Need help resolving these issues.
You probably need to give a bit more information for people to help. Like, what are you expecting the image / text to do vs what it is actually doing (URLs or screenshots, would help).
When you say the developer has not resolved the issue is it because they’ve tried and it hasn’t worked or because they haven’t gotten back to you. If it’s the latter, tagging @Lucas so he’s aware.
Thanks for the info. I’ll resubmit the info after the Tottenham / Ajax match
Richard
Thanks @jabostick
Please send me more info on the issue @Rich01
Sorry for the delay, work got in the way. Here are two grabs of one of my pages.
As you can see the formatted text does not correspond with the output. The “what’s included” is Header 1 with a grey font. The “everything” is also a grey, header 2.
All type is centered but shows justified left. Also the word “slight” is italic but shows up in red.
I look forward to your reply.
Hi Lucas,
I’ve just posted on Realmac and here is the problem.
Hey Richard,
For the content check the Center Content option at page styles.
As for the italics in red: I’ll have to make a new option for it in the upcoming update, for now you can use the snippet below at the page CSS field:
em { color: black }
Hi Lucas,
Thanks, that seemed to work. I will try and apply it to other pages once I have the time after my shoot.
Richard Swiecki
Digital Product Shots
647-704-7064
