RW8 Themes banners not responsive
When creating a new site with RW8 none of the new themes banners are responsive. If I pick an old theme they are.
Hmm, odd. Not sure 100% what you mean, if you could email dan@realmacsoftware.com with an example and I’ll look into it for you.
Dan
While talking about themes - I really like the new themes, but is there any way to make them cope with multi-level menus with sub-pages?
meaning the image is not resizing prepositionally.
It’s easy to do. Take a look here:
https://d.pr/i/KlJEVo
I think @snail47 is talking about sub-sub menus and deeper.
Not even that! I tried applying the themes to an existing site that has just one level of sub-menus on two of the pages (marked with a dot):
When applying the new Artful theme (the other three do the same) I get:
So I’m not sure what, if anything, can be done!
@snail47 — Can you send me that project so I can take a look at this - dan@realmacsoftware.com - we’ll get the theme fixed up so it handles this better.
Hey Brian
What app did you use to make that screen recording with circle around the mouse pointer?
Thx
Thank you Dan - just sent it.
Thanks, just sent you a reply :slight_smile:
Thanks Dan for the quick response as always!
I used Droplr to do that. I have a Droplr pro account and it includes screen capture tools built in.
Thank you Brian
Thanks for the help and advice Dan - false alarm!
