I recently added XAMPP to develop locally. When I exported the pages to my folder I discovered my prefixes were set for the actual website and got a database error so I rewrote the prefix in the index page within the folder and everything works fine, but now when I add the new prefix to Rapidweaver I get a message that there is a database problem.
Please note that I’m using sitelok as my registration and login agent. Please note that it’s only when I add the below prefix directly into Rapidweaver that I get a database error. Is there another way to point to the directory? Here’s the code. Thanks.
Yes, but it keeps adding ‘http://’ by default and wouldn’t work so I pointed it to ‘http://localhost/jurugo’ and it’s still not working.
I used the mac default apache webserver (also added mysqi & php) at first but I had to use a password with every edit. It was cumbersome to say the least. I’d use mac websever if I didn’t always have to grant permission. I can’t find anyway around that. I tried sime temunal cmnds suggested online to no avail. That is why I migrated to XAMMP.
Well that didn’t work, but I got to looking at the tools section a little closer thanks to you. I went to advanced and changed the relative path to website and “presto” it’s working.
