SFTP tests OK, but publishing fails
SFTP for this site works fine to upload images using Cyberduck. Host is dreamhost.
In RW publishing FTP works fine: the test is successful, “Browse” opens a window showing the contents of the root folder, and publishing works.
When I switch to SFTP the test is successful, but “Browse” cannot find the root folder, and publishing doesn’t work.
Here is the setup:
Here is the success message:
Here is the error message on clicking on “Browse”
Hi @rtloon
Try removing the / from the beginning of your publishing path and see if that makes a difference.
-Greg
@barchard
Greg,
That did the trick. Thank you! Interesting that the / works for ftp and not sftp.
And thank you for doing the Weaver Space podcast with JW. I appreciate the prework you do to identify details to explain. Your adds make a big difference.
You’re welcome. I’m really glad you enjoy the podcast with @joeworkman and I too :slight_smile:
