Is there a simple solution to single page navigation in RW?
I wish to link to sections on the same page from the main menu. I’ve done a considerable amount of searching and can’t find a solution.
Big White Duck has MagicGellan but this seems to work only with Foundation and I have Foundry.
Seems like a simple thing to do. I have transferred from Adobe Muse which had this feature baked in as page anchors. I feel like I’m missing a simple fundamental piece of knowledge.
thanks for the suggestion. It looks like it will be a solution, although it means purchasing way more than i need.
I just thought that it would be such a simple thing to do that I had overlooked a built in method like in Adobe Muse.
I’m pretty sure you could use the link stacks @teefers posted in conjunction with a menu stack like one little designers clean menu, other menu stacks that allow custom links too probably, to get the effect you are after.
You could also add your anchored links as offsite page links in RW to make them part of the RW menu.
101 Ways to achieve this. I’ll add one which may seem a little arcane, but does prevent you from having to add a bunch of pointless offsite page (links). Assuming you are using the standard Foundry nav stack…
Now, customise the href links in the $links_arr to point to any html stack you fancy, anywhere you like on the page. Inside each html stack just add something like:
<div id="area_one"></div>
Thats just an empty div, of course, but the ID it uses corresponds to the href target in the content being injected into the main menu.
Not saying this is a perfect solution, or has been tested for compatibility with everything else under the Rapidweaver sun … but it works and avoids the need for extra stacks, apart from the very lightweight HTML stacks and it prevents having to add offsite pages (which they themselves would still have to point to something anyway).
thanks for the link. I’ve tried it and it works with buttons in foundry although it’s not very elegant. It jumps rather than scrolls. Which may be fine.
thanks for the suggestion. It is probably a bit too complex for my level of expertise. I’d much prefer a solution that means the CSS and javascript is kept at arms length.
