Something better than PaySnap and 'Gallery' advice please?
Hello,
Please could anyone be so kind as to look at my website and help me with two issues?
  1. Is there anyway I can add some code to the stack to make the ‘click to enlarge’ text smaller, so that it works more aesthetically.
https://deborahgriceartist.uk/portfolio/paintings/
and even/or better…
  1. Please advice me of a less clunky way of making a site that functions like mine does (i.e.thumbnail images that click through to the larger image with further details). My way of building my site seems laborious.
I used to sell through my site, but now I rely on galleries so the paysnap function is no longer necessary…
Thank you :pray:
Hi @Pipspaws,
If you add this code:
.paysnap-show-details {
               font-size: 1.0rem;
…here:
… that bit of text should be a bit smaller. You can play around with the “1.2rem” bit of the code (the smaller the value, the smaller the text will be).
As for your second question:
Building galleries is labour intensive. There are automated solutions out there, but they can be a bit expensive. If time is money, they might be worth the investment though.
Gallery 3 ($40, inStacks Software) is one of those. It allows you to put the images in a folder on your webserver (and label them) using an FTP client like CyberDuck or Transmission, and then the Gallery 3 Stack will use those files and labels to build a gallery for you, automatically.
ProGallery ($30, Stacks4Stacks.com) is a similar product, but slightly cheaper. It allows you to configure how the gallery works a little more than Gallery 3 does, but you’ll need to use a CSV file to do so.
Erwin
Slightly incorrect; ProGallery 3 supports various image sources, not just CSV. You can easily add images individually or give it a relative path to a RW resources folder or web directory of images for it to use. There are multiple ways to add images to a ProGallery instance. Please try the free trial version to see for yourself.
If you are a member of my Discord group, you’ll see I also started to share a few details of the forthcoming Pro Gallery 4 update on there a few weeks back. Soon Pro Gallery 4 will be the only gallery solution for RapidWeaver and StacksPro worth using when this major update is finished. A culmination of listening to what real artists and photographers want and several months of developing one of the most sophisticated gallery plugins available for any platform. :slightly_smiling_face:
@Heroic_Nonsense Thank you so much for the code, it has worked beautifully. Thank you also for the stacks advice - I will look in to both.
@willwood Hi Will, Thanks for the stacks input. I have looked at https://stacks4stacks.com/progallery/index.php and see that your stack should work really well.
I have two questions please: Can I add text to the thumbnail page? Secondly, is it worth my waiting until v.4 before I purchase it?
Thanks, Debbie
I stand corrected Will (and so does my post)!
Erwin
Titles and captions are feasible on both the thumbnail grid and the lightbox, using ProGallery 3.
I’ve sent you a private message regarding the pricing and availability of Pro Gallery 4. I can get you setup with something within the next couple of days and convert your existing gallery over to use Pro Gallery 4.
