Something PRO happened: RapidCart Pro is here!
Follow us on Twitter to be the first to know :wink:
RapidCart Pro 1.2.1 has just been released!
Enhancements
Updates Mollie framework to version 1.2.7.
Updates Stripe framework to version 3.1.0.
PHP version checking function is now more reliable.
Bug Fixes
Fixes problem with Mollie SSL certificate check.
http://realmacsoftware.community/rapidweaver/addons/plugins/rapidcart-pro
http://4gnd.com/rcp
RapidCart Pro 1.2.2 has just been released!
Enhancements
Enhances plugin UI on small screens.
Bug Fixes
Fixes broken PayLoom import after PayLoom 2.0.6 update.
http://4gnd.com/rcp
RapidCart Pro 1.2.3 has just been released!
Enhancements
Shipping and payment fees can now be less than 0.
Bug Fixes
Fixes Catalog pagination not working on Nick Cates’ Forward theme and other 3rd party.
http://4gnd.com/rcp
Hi gibo,
Can you post a link to the current release notes for Rapidcart Pro please? Also, even though i just updated, the version number in the stacks 3 library says version 1.1 for the cart, grid and product stacks, and the plug-in info in RW says 1.2.3. Is that all correct for the latest versions?
Thanks,
dave
You’re using latest version of RapidCart Pro (1.2.3) and RapidCart Pro Stacks (1.1).
Release notes are in included in this thread.
Let me know if I can be of any further assistance.
Thanks gibo. Wasn’t sure about the version as several days ago i had already done what i thought was the update to 1.2.3 and 1.1, and then yesterday was notified of another update, and clicked download before reading the notes.
By the way that cart stack is a great addition!
RapidCart Pro 1.3.0 has just been released!
New features
Adds support for styledTextView long product description.
You can now freely search by keyword in categories and tags.
New ā€œShare on Pinterestā€ button for products.
Adds SmartPreview support.
Enhancements
Improvements in Google PageSpeed Insights ranking.
ā€œFreeā€ label is not shown in Payment and Shipping windows anymore.
Updates UIkit framework to version 2.22.0.
Updates Stripe framework to version 3.2.0.
Updates Mollie framework to version 1.2.8.
Bug Fixes
Fixes missing ā€œTaiwanā€ to country list.
Fixes improper use of CDN resources over HTTP when using HTTPS.
Fixes ā€œUndefined Variableā€ PHP Notice for Amazon service in Checklist page.
RapidCart Pro 1.3.1 has just been released!
New features
New SmartPreview utility enables offline preview.
Bug Fixes
Fixes products images layout problem with some 3rd party themes.
Hi, Gibo,
I’m a bit confused with stack updates in stacks3 - do the new versions of the stacks have to be manually replaced on pages using the old versions?
thanks!
Stacks should warn new about available stacks updates. Once updated, you’ll just need to republish your Stacks pages containing RapidCart Pro stacks.
In case you’ve missed latest Foreground’s tweets:
RapidCart Pro 1.3.2 has just been released!
Enhancements
Updates PHPMailer framework to version 5.2.11.
Bug Fixes
Fixes product version boxes not visible on Firefox and Edge.
Fixes broken product images on SmartPreview when using local resources.
Fixes missing ā€œTaiwanā€ in ā€œDefault Countryā€ popup menu.
@gibo
hi mate I downloaded the free version of RCP to try out. I’ve been playing about and it looks great. The question i have though is about http://rcpro.4gnd.com/demo
I navigate to this page and it will not scroll down (to the bottom of the page, I only see half the products). Not sure if its something the matter with my system but my strong suspicion is that Safari 9.0 is to blame for this as I can’t replicate the issue with other browsers (Opera, stainless, Chrome, work just fine)
has this been raised before and if so is there a workaround?
It seems an issue between theme picker we adopt for theme gallery and Safari 9 beta. Thanks for pointing this out. We will have a look at this.
As a side note, stores created by RapidCart Pro are already compatible with Safari 9. See Foreground Store
Yeah I was confident that was the case!
thanks for your reply and as a wee side note here’s some more browsers
Slender No issues
wwwDOT! No issues
Maxthon NOT working
Torch No issues
just for info
G
…and, well, thank you! :tada:
SmartPreview 1.0.2 has been released!
It’s included in RapidCart Pro DMG or available thru automatic update.
Bug Fixes
Fixes occasional can’t connect to server error.
RapidCart Pro 1.3.3 has just been released!
New features
New pagination setting to show page number on top and bottom of catalog page.
New ā€œ#rc-contentā€ HTML wrapper.
Adds support for remote product image URL editing.
Enhancements
Updates PHPMailer framework to version 5.2.12.
Reduce memory footprint when working with multiple projects.
Drastically improves import speed for large projects.
Bug Fixes
Fixes products sort by name when using uppercase and lowercase letters.
Fixes wrong calculation in min and max dates using ā€œDateā€ option.
Fixed broken product layout when using small or medium gallery on mobile devices.
Fixes version problem with imported product from RapidCart 3.
I want to sell products on a monthly subscription. Is this possible within Rapidcart Pro to define a re-occuring monthly credit card payment through Stripe?
Cheers
