I wrote a number of website for my company with RW, but I was appalled when being reported that SonarCube, the web validator they use, did non pass the code reporting well over 50% of errors! Does anyone have the same problem and is going RW to fix it?
I’ve not used SonarCube before, so I’m not sure what it’s checking for… But generally the code RW produces is pretty damn good for a WYSIWYG tool.
A lot can depend on what theme and thrid-party add-ons you’re using. Could you expand on how the site is built?
Cheers
Dan
I am using the simple Realmac Software '06 theme for that site, could the errors depend on the theme I use?
In addition I simply use Stack and no other fancy things.
