Source Project: Gradient. Featuring "Super Hero" Header
This one was quite some time to the making, but I’m super pleased with it.
Gradient follows in the footsteps of my previous template called Kitchen, using clever layouts and gradients to create a beautiful website that really catches the eye. But Gradient takes things to a whole new level, maxing out the power of the Source Addons pack, in particular Grid Plus, to produce some amazing layouts, including the “Super-hero” header: Which takes the Source trademark “Spiral” Grid design and turns it into a fully scaling responsive full height hero header.
Super Hero consists of a grid that changes layout and number of panels based on the width of the screen. Change the browser width to see it in action: SUPERHERO
If you want an impactful header on your site, you need Source, the addons pack and the Super Hero header :slight_smile:
Gradient also includes two “manually curated” menu options that use Source buttons and the regular Source menu, but in mobile mode. And Source buttons and BWD’s PopDrop menu. Checkout the MANMEN & POPDROP pages for demos.
As with all my projects I’ve focused on usability, ease of navigation and giving you lots of different layout options all using the same overall design. Use Gradient “as-is” as the basis for your next project, or drag and drop elements into your existing projects.
Gradient will be priced at the usual cost for my multi-page projects, with the usual launch discount applied.
See the demo here: HOME
Buy it today for only €14 here: Buy pre-built Rapidweaver projects and templates.
As well as Source and the Source addons pack Gradient also uses some free stacks from Big White Duck. Links are supplied to these stacks in the store, and don’t forget to make a donation to BWD too :wink:
EDIT: Should also mention: Gradient comes with a choice of menus. There is, of course, the regular Source menu, but I’ve also included two “manually curated” menus that use Source buttons and the regular Source menu, but in mobile mode. And Source buttons and BWD’s PopDrop menu.
Nicely done!
Really nice project @TemplateRepo! The superhero header is great!!
Hi folks, just a heads up that all good things have to come to an end, and so the launch special pricing will end in a few days.
If you want to join the loads of people who have already bought this project at the cheap price, get it bought asap!
Cheers.
