Stacks API Custom Control Reference - Math
Custom stack question…
I have adjustable height and width inputs.
I want to set a third variable based on the input of H and W.
Specifically the new variable is X = Width - (Height + 4).
How do I set this up in the pList. Is the Math the correct custom control and how would you setup the corresponding arguments and operators. Also, I don’t see ID reference under math. But, I need ID to place the result in my CSS variable that changes in relation to W and H.
Thoughts?
I think I responded directly to your email to us, but I wanted to respond here in case anyone else has a similar question.
It is best to ask developer and API questions directly to Isaiah at http://slack.yourhead.com
Christi Carew
YourHead Software
http://www.yourhead.com
