Hi Chuck,
Expander built into OS X Mojave.
/jvs
Hi Chuck,
/jvs
Hi Paul,
Yes. I have tried to delete everything I can find.
Strange thing is that only stacksinstaller restores the file extension of the directories to .stacks.
FORGET STACKS INSTALLER !!
Isaiah, the inventor of Stacks has told you to trash it, why are you persisting with it?
Bin RW then go bin anything in the ~Libary folder called com.realmac.whatever
Then reinstall RW in the Applications folder.
Fire up RW ⦠Youāll have to renter your RW licence no as it was stored in the prefs youāve just trashed.
Iām no expert, but Iāll give you my ⬠0.02. In my opinion the Finder has a problem with associating the āstackā extension, as has been said by @Isaiah and others.
That reminded me that others and I had a similar problem some time ago (in 2016) and I found the forum post in which I participated: RW Project Files saving as Folders - ElCapitan You might download and install the RCDefaultAPP (it still works) and have a look at the association of the āstackā extension.
As you can see in the screenshots, it is associated with RW8 on my Mac, but it can easily be changed.
There might be other apps which can give you similar information, but this little PrefPane restored my sanity a few times, so Iām happy it still works.
i suspect this is just a language-translation/native-speaker type thing ā but i just wanted to be clear: i definitely did NOT say that āthe Finderā has a problem with the stack extension or any other extension either.
i did say and will now reiterate: all signs point to a problem with @notimeflatās Finder.
in other words: i donāt think that this is a bug in anything. i suspect that @notimeflatās macOS has decided to stop indexing apps ā either due to an installed utility or perhaps just general chaos that happens to us all over time.
and i suspect this is exactly what @macmenno was trying to say ā but like i said, i just wanted to make that clear.
iāll also reiterate my suggestions for resolving a problem with the Finder since they seem to have been largely overlookedā¦
Iāll give you one last test you might try too: you could create a separate user on your system and see if that user has the same issue. A separate user will have a different set of file-associations for the Finder so, at least in theory, the issue could be resolved there.
That doesnāt really solve your issue however ā unless you donāt mind switching to an entirely different user account (I sure would). But it will at least give you some indication whether the problem is user-specific or something larger.
Outside of that last test, I sincerely think that youāve exhausted all possible avenues of assistance the forum has to offer. I suspect your quickest route to getting back to work is to visit an Apple store (or similar) or reinstall your OS.
Or, simply ignore this problem. As I said above (also overlooked, I guess) Stacks doesnāt care if they look like folders or have the nice little yellow icon that I drew a few years ago ā as long as you put them in the right spot, theyāll work just fine that way.
