A half dozen of the stacks pages in my site (with over two hundred stacks pages) no longer go into edit mode.
The whole bar with the library, partial, hide, lock, etc. bar is gone from them. How can I get it back, hopefully giving me some option.
The toolbar in Stacks is an integral component of the plugin – it’s built on native technology and there is no way to hide it. No content, project setting, or stack property can alter that.
Short answer: something, somewhere, is very very messed up. I’d recommend:
Isaiah
Ouch. That does not sound like fun. Will have to set aside some time.
Is there some way to figure out which add-ons are not in use? I know over the years I’ve bought some that are probably not in use any more, but I have no idea how to determine that.
Even looking at some pages, I’m not sure which add-ons I used to get the effect. And there are 219 pages in this section of the site, 201 in the second section, and I haven’t counted the other 3 sections.
@RichardLW First: it should be easy enough to figure out what stacks you are using. Or plugins. If nothing else, write them down then check against the list of stacks/addons in your relevant folder.
When you go to your addons folder in the Finder sort in columns by date. It will be immediately obvious which ones are old. As a rough estimate I’d pull out anything older than 4 years.
The problem is not the number of pages you have (although you have a lot) it’s specifically what stacks or plugins you are using. It could be across the many pages you are only using 10 different stacks and no additional plugins beyond Stacks. In that case I’d pull out all the unused stacks and plugins from your folder. I’d archive them by putting them in a newly created folder named something like “Archived RW Stuff”.
In your case this could be a very long process, or relatively simple. It’s hard to know at this point.
If that sounds daunting, let’s give you a quick and dirty way to find out 90% of the info in about 5 minutes – less time that it will take me to write out these instructions. ![]()
In less than 5 minutes you’ll know:
In other words, in about the time it takes to write a forum post you will have either solved the problem, or be well on your way to solving it.
Don’t worry. You’ve got this. Give it a go. ![]()
Isaiah
Also: It would probably be a good idea to show me a screenshot of one of the affected pages. Sometimes that bit of visual detail will give me the bit of extra detail I need to help you solve your problem.
Isaiah
Thanks, I will try that on Monday, as I am on the road and patching through my telephone this weekend.
Here is a shot of one of the pages that does not work right. It goes blank for several seconds when I click on that page, instead of coming right up.
BTW, MacBook Pro, 2016, 2.9 GHz i7 with Mojave 10.14.1
