I’m new to RW and try to rebuild the stacks + foundry youtube tutorial page. Although I’m doing the same things as in the tutorial, my page doesn’t start as a blank one like seen in the video. Any hints?
Theme in use
You have to make sure you “start” with the correct theme or template -
Most likely foundry has a standard theme which is blank. So if you are using default theme which comes with Rapidweaver, you will get what you are seeing.
Go to the inspector side bar and the second to last tab you will see which theme you are using and make sure it’s the one foundry needs.
Thanks. That helped. I have to choose the foundry theme
Yes, the Foundry theme is essential. be sure to choose it from here though, and not in the Page Inspector:
Thanks again
