I have a 2 year old blog post (using Tumblr stack) and 3 redirect pages no longer displaying properly, I assume this happened after the latest update. Can anyone share some wisdom to get this running again.
The live page shows: “An unknown error has occurred. Please try again.”
Thank you for your comment. I removed the adds with no change. I do not understand why there would be bad credentials as the tumbler stack uses the Tumblr domain: collegefootballanalytics.tumblr.com which is working well outside of RapidWeaver.
How long has it been down? maybe it’s a glitch on tumblers side. Or maybe they changed the api, although I would expect others using the stack to be posting if that were the case. Do you have the latest version of the stack installed?
Be sure your stack is up to date, check the settings in the stack and republish is about all I could suggest.
