Hi
having this problem with super flex. just happened randomly. was fine previously.
any ideas?
all padding and margins set to zero…
update - this happens when an image is misplaced in the flex stack. If you are not careful its easy to place an image BETWEEN the image placement boxes (you can tell as there is no number associated with the image). doing that breaks the layout…
