Thanks for reading.
Could anyone provide a piece of code to change the background color of Extracontent Areas in Tesla Pro?
Thanks in advance.
Pablo
You can try this:
#extraContent1 {
background-color: #0000ff;
Change the 1 to 2 for the second EC area. And of cource change the color. If that doesn’t work will need a URL to give much more help.
Thanks for your fast help Doug,
I put the code inside configuration CSS. Unfortunately it doesn´t work.
I´m building the page. Hopefully I will upload a sketch of www.paresbiomagneticos.net tomorrow.
I don’t have the theme I’m afraid but I’m surprised it’s not in the Master Styles settings as colour picking option.
Rob
Thanks Rob.
Unfortunately there is no color picking option for EC areas. I´ve even tried to change the background color in the extra content panel but doesn´t matter.
Not sure what you mean by that.
I just tested it with a stacks page using the following code:
#extraContent1 {
#extraContent2 {
background-color: #00ff00;
I tested with the code both at the page CSS:
And site wide code settings:
And it worked fine.
Thank for your time Doug.
Great explanation, step by step. Appreciated.
I mean I put it here (cause I want to change color for the entire theme, not just for a page):
I´m working with RW6, and I don´t know why but it doesn´t work for me.
Have you tested it with Tesla Pro theme?
Yes using Tesla Pro for this test. Using s4s - extra content stack, RW7, and a single stacks page. I don’t have a lot of experience with EC areas and almost never have used a nonstack page. If no one else can help once you have published give a shout out.
Thanks once more, Doug,
I haven´t change anything but when I opened my RW project this morning, your piece of code is working fine. So solved. Thanks for your time. SOLVED.
In addition , I am still wondering why changing the background color inside ExtraContent Panel setting do nothing.
Anyway THANKS
