Hi, I have just signed up for Rapid Weaver and am still finding my feet. Does anyone know why I cannot select a theme and have it show up on my new page/site. I have followed the instructions given on the tutorial video for setting up a 3 page site in five minutes very carefully, but cannot activate any of the themes. I realise this may be something simple I am failing to do, but I cannot figure out what. Any advice would be much appreciated.
I’m not sure I understand your question. To select a theme you goto the upper left part of the screen and push the theme button. A window will open along the bottom showing themes. Just click and it should apply after asking to confirm.
Push the theme button again and it will close the theme window.
I have done that and all the themes are appearing underneath the blank page, but when I click on any of the themes nothing happens. The video tutorial implies that that clicking/selecting a theme should move it onto the page, but so far this has not happened.
Themes are not moved to a page but are applied to the content of the page. If you have a blank page you won’t see anything happen. Add some content and also try the preview button to see how themes will look.
I might be stating the obvious, and you might have already done so, but just incase - have you clicked on “Preview” after applying the theme? You won’t see anything change on the page in Edit mode after applying a theme to blank page.
Thanks to you both. I figured it should be something simple. I did check the preview but clearly the lack of prior content is the issue. Many thanks.
I should have mentioned the need for some content on the page to see the applied theme. Glad it helped though and now you’re up an running.
All good now. Thanks again.
