Hello,
I am designing a page based on the split theme.
But I need more navigation levels as you can see in the picture.
Target is to have the labels Simba, Nala, Lisha in one row and if I select for example Simba
the subpages navigation will be visible.
Alternative maybe there is a possibility to add a sidebar menu with the third level content.
I had exactly the same problem.
The workaround for me was to use grids, having the first grid limited to 20-25% of the width.
In this area I put ābuttonsā which I linked to the third level pages.
Done
Just make sure you have deselected the āshow in navigationā option in the Inspector for all pages in Level 3.
Hi there, I have only two levels for the navigationā¦but when one clicks on the second navigations, the first ones disappear and canāt āgo backā and click on them.
The only way to āgo backā is to use the arrow on the Safari search barā¦
Also, I used to work with Rapid Ideas Konzern Theme, and Richard Christoph had all these great multilingual snippetsā¦which I leftā¦ Seems to half work.
Any thoughts?
Thank you !! This forum has helped me tremendously over the years, but been about 7 since Iāve been on again.
Hope you can help.
It wonāt work as Split is only possible for 2 levels deep.
For 3 levels deep it would be best to add a link maybe above āwhat people are sayingā¦ā and say ābackā or something?
Thank you Michael!
I thought my site was already a 2 navigation level site, but seems I counted wrong.
Youāre a genius. Thanks for the code.
Thatās the perfect solution.
May I ask one more thing? Any tips on getting creative with code to make the ābackā text a different colour, or within a nice neat border/button?
Is there some Code manual that has all the code I need to do such tiny tweaks?
Great. here it goes:
Topic: SPLIT THEME - MOBILE FRIENDLY - tweaking top navigation barā¦
Iām loving Split theme, itās clean and simple, though, I was using Rapid ideas āKonzern Themeā for years, because of the multi language functions, (but Konzern is not mobile friendly).
Split Theme is great. The thing is that, Iāve kept all the previous Konzern Themeās language snippets and the layout with different languages pages (I created all pages/sub pages in English, and then copied and created the same for Spanish and Portuguese).
It seems to work OKā¦even without deleting the Konzernās javascript code for the language snippets.
My enquiry/question is this:
When my site is on a mobile, not all the top navigation ālanguage titlesā come up.
On a desktop, you see the top navigation as: English, Spanish, Portuguese and Catalan.
On a mobile, on the home page, you only see the last language from the top nav bar, in this case being āEspaƱolā.
apologies for late reply, I was on a plane!
Iāve checked it out and changed the background header as you suggested.
Re: the CSS, where did you delete it?
The only CSS I have on each page is the CSS to change the main images.
See screen shot.
Could you tell me what and where you went to delete all the CSS?
