Yes, that works, thanks. Only thing is, now it shows up on desktop computers as well. @tav couldn’t figure it out/reproduce it, so I am using this code. Maybe @joeworkman or @zeebe can check it out after the weekend.
thanks, Doug and Scott
I’m out of town and don’t have computer but I seem to reacall a setting… show parent or similar. Maybe that has something to do with it.
If not then my guess is you will have to add an @media. Query to front of above. To keep it from showing in desktop.
Sorry, about all I can do from here.
This is a known bug. Sadly it cannot be fixed with a snippet. I filed the bug with Zurb and they have fixed it but have not yet released it.
Wow. No wonder none of us could figure it out. Thanks for letting me know, @joeworkman. The snippet above, withOUT the @media works, though as mentioned, then doubles the parent menu. I guess that’s better than not being bale to select the top menu at all?
I do wish Zerb would set up separate settings for tablet portrait and landscape. This would be a great feature.
and @joeworkman… Earth Day from the treadmill doesn’t count
This should fix it so it is not doubled and bring back the borders on the “in-between” size:
@media only screen and (max-width: 780px) {
li.parent-link.hide-for-medium-up {
display: inline-block !important;
.top-bar .top-bar-section li {
border-bottom: 1px solid #900;
border-bottom-width: 1px;
border-bottom-style: solid;
border-bottom-color: rgb(153, 0, 0);
Doug, you are a genius! or you are very good at figuring out code, at least!!! thank you, thank you, thank you!
@joeworkman @teefers figured it out!
