Topic for next podcast
Hi Folks
Would like more information on Resources. Your Video tutorials are a good starting point as is Joe’s Foundations & Stacks video (I think it was). However, I have some queries…
  1. Can resources macro be used in any stack/Theme where an image or file is asked for?
  2. Using Resources is pretty much the same as warehousing is it not?
  3. As I have several html files in my root and use folder structure for other things, when I use a resource macro for an image it still publishes as /pagename_files/resources/mages/filename.ext. It should publish as /resources/mages/filename.ext (does not remove the /pagename_files/ from the published page or the exported page). I have even tried to delete the image and redo it using a resource macro immediately and no change.
Brad
