Twitter feeds on Standard iPad Air 2 not mini
Hi all,
Here’s a weird one. Cannot understand why my twitter feeds do not show on an iPad Air 2. They show on iPhone and an iPad Mini 2 though, any ideas?
Also if you take a look at my website, www.skydart.co.uk if you look at the very top I have a white line! Weird. It appeared when I embedded the iubenda code for my Privacy policy and it then created a white button you could press to navigate to the iubenda.com website to view the privacy policy. Well, I have since removed the embedded code and it’s gone, having set a direct link instead but the white bar at the top remains. Any ideas how I can delete this white line?
This should work to remove the white line:
body {
margin-top: 0px !important;
You can paste it in the Site Wide CSS code in Settings to have it be applied to all your pages.
Hey,
That works really well. I’m so very grateful to you.
All the best.
I don’s suppose you know a way of making a responsive theme wider on an iPad too do you?
Anyway, many thanks.
Glad it helped. :slight_smile:
Not sure what you mean by making the theme wider. Do you mean less margin on the sides of the content?
Any ideas anybody why a twitter feed does not show on an iPad Air 2 but does on an iPhone 6s Plus as well as an iPad mini?
Same iOS version?
(at least 20 characters)
Is there possibly an add-blocking extension like Ghostery on the iPad Air?
Yep - well thought of.
Many thanks for your insight and thanks to peppermint for joining in and yes, same IOS but I indeed have discovered a ad blocker on the iPad.
