hallo mighty rapidweaver pundits,
a very strange thing just happened: i wanted to update a site from rw 5 to rw 6 and duly went into my trusty rw 5.4. fortunately i exported the site to a folder first. then i got prompted to update 5.4 to 5.4.1 which i did. i also updated all the stacks, not having used 5.4 in quite some time. after the restart i find that i am unable to export my site to rw 6!? the menu item just completely disappeared! what happened? quite puzzeled…
greetings, tomas
You don’t have to export it anymore. RW6 opens it, then creates an RW6 project.
The upgrade guide reflects the updated flow for getting your documents to RW 6:
http://realmacsoftware.com/rapidweaver/upgrade
—Nik
