Send Report clicked. All the files seem to export correctly. Only one index.html in the root directory, but every sub-directory has an index.html file in the appropriate folder.
This is the same site, successfully published with Version 7.3 (18575). This also publishes OK to a local folder.
Many thanks, much appreciated. I run the Betaโs for the new features, but I always keep the old versions just in case
Have a major issue here with 7.3. When the publish fails to connect stating a problem with the path, and one simply clicks on โcancelโ, all I get is a spinning dial and there is no way out other than a Force Quit. Happened over and over as Cancel does not cancel.
Thatโs solved my issue thanks. Beta 3 now publishes (locally) correctly and finishes with 'Done" allowing me to close the publishing box correctly without have to do a Force Quit.
Well done chaps
RapidWeaver 7.3.1 (18606b) Public Beta 4 is now available:
https://dl.devmate.com/com.realmacsoftware.rapidweaver/18606b/1489754922/RapidWeaver-18606b.zip
Changes:
- Duplicating a page should no longer load all pages
- We now log to the console when a page is loaded
- Fixed an issue where page migration could be called unnecessarily
