Updated to RW7.1 and i've lost edge to edge images on a site
Hi guys,
I’ve just updated to the latest version of 7.1 from 7.0.4 and a site i’m working on has lost the ability to show the header and an Xtra content 3 area edge to edge.
I’m using the Geometric theme from Elixir Graphics
Here’s how it should look on my test server
and here’s how it looks in Preview
If someone @Elixir or has any ideas it would be much appreciated.
Many thanks
Hey there @Mike1052!
If you want to email me your project file I can have a look at it for you. Send it over to adam at elixirgraphics dot com and I will take a look. Link to this forum post in your email too if you wouldn’t mind. Thanks!
Hi Adam,
Many thanks for getting back, i’ll do that now.
The project file is 350Mb so i’ll have to get that over to you with WeTransfer ftp ok
All the best
Mike
When I loaded your project file it seemed like one of your stacks was missing. I checked it out and it was the ExtraContent stack. This is odd because I of course have the ExtraContent stack installed. I added a new ExtraContent stack to the page and moved your Orbit stack from the defunct EC stack to the new one and all started working again:
Give that a go and see if that clears up the problem for you as well.
Hi Adam,
Perfect, i did exactly as you explained and all is as it should be, i’ll
replace all the Xtra content stacks on the site again. Strange as i have
this stack in my library too.
Many thanks for your time and help, much appreciated.
The strange part in all of this is that when i migrated over from RW6 to
RW7 i had the same issue with a spacer stack, when i opened the same site
after installing 7 the spacer stack disappeared and i had to reinstall that
and replace all my spacer stacks.
Obviously not the end of the world, but a slight pain to say the least for
a simple change of RW version.
I’ll get over to the forum later to mark this as problem solved.
Once again many thanks
All the best
Mike
