Upgrading from 4.4.2 to 7.5.5 = problems
Using Mac Sierra 10.13.3.
I have to manually enter my site/ftp password after reopening Rapid Weaver … every time.
My categories disappeared from both my sites. Using ‘bravo’ and ‘possible’. I found where to add or subtract categories; after much digging, they are still there, just not on the site after publishing.
I only upgraded to ver 7.5.5, because I upgraded to Sierra, and I noticed I couldn’t add links in ver 4.4.2. … figured I’d update after all these years.
Is there a version in-between 4 and 7 that works in Sierra that I could use?
Did you follow the steps to upgrade to v7?
https://help.realmacsoftware.com/support/solutions/articles/36000001229-upgrading-sites-to-rapidweaver-7
Hi Don,
Followed the steps after the fact; thanks to your suggestion. I uninstalled ver 7, then followed the steps as outlined in the link you provided.
Same issues. Categories are missing. I have to enter the ftp/site password. I also noticed my gmail is acting wonky … have to enter the password every time I open the mail app.
The problems are bigger than the benefit of the upgrade. Can’t go back to version 4.4.2 … no longer compatible.
Maybe this would help?
Yes. Same problem I’m having I’m having if thats what you mean.
Okay … disregard the gmail issue. It’s an apple problem. Still no categories, still no saved site/ftp password though.
  • Update*
In fixing the gmail issue, I was able to solve the password matter. Keychain.
Now I have to figure out how to get the categories to work.
