Rapid Weaver 7 upload problem
Hi, Just updated from RapidWeaver 6 to RapidWeaver 7. When I try to re-publish my website I get the message " couldn’t upload to your FTP server ( retry in 5secs). " When I test my connection there is no problem. I have contacted the hosting company and there is no problem with my settings there. So it would appear to be a RapidWeaver7 problem. Is there a solution to this? Stan56
You may have to re-enter your password in your publishing setup and bookmarks. If that’s the case, it’s a Mac OS/High Sierra thing, not RW. If not, you may need to provide a bit more info on the issue
Thanks Jason,
Probably a Mac problem. I will check this.
Regards,
Stan
