How can i set up the video player in my RapidWeaver project?
Do hide the big play button on the video and if i want to change the size on the desktop how can this be done?
Thanks.
Thanks.
Hi Lars,
It’s all there in the Stacks settings of Videoplayer.
Videoplayer is responsive. To define the size on the desktop you should place Videoplayer in a container and define the size of your container, or use margins. There are different options here depending on Theme or framework (such as Foundation or Foundry). Layouts stack by 1LD can be helpful as well to define the size.
