WeaverTips - The best tips for RapidWeaver
awesome. thanks! yes, i want to do a lot more on Partials. Next week’s Tips are queued and ready to go. Stay tuned!
AWESOME! Thanks for doing this. Looks great.
Lovely idea, but I have problems visualizing the tips on Safari 10.0.2… the GIF loads but doesn’t loop so in a moment the picture space becomes blank. On Chrome 55 everything works fine. I’ve tried to message you directly from the site but the form returned me an error.
Do you have any extensions installed?? Works great for me in Safari 10.0.2.
Yes, you’re right! An old extension was the culprit… Now working as is as to do :slight_smile:
Hi Greg, I very much like the idea. However I happened to click on Create a Partials in Stacks and found that the images do NOT display. The first image flashed up for a fraction of a second then went blank white.
Thought you might like to know this.
hi, others who have had similar issues had some Safari extensions installed. Please make sure there isn’t a safari extension conflicting. also, the GIFs can be quite large. Please be sure to let them fully load
How’s everyone liking WeaverTips so far? I have another week of content lined up and a back log of new articles to write.
Please keep the awesome feedback coming! I look forward to all of the tips. Please be patient while I work through my list.
-Greg
Last week was an awesome week with the launch of PlusKit 4. I posted a couple extra GIFs on launch day for PlusKit users.
I have another week of content lined up. I’ve been posting new GIFs every week day. The best way to stay informed at the moment is via the RSS Feed. Would a weekly email summary be something users are interested in?
-Greg
PS. Thanks for all of the great tips. A few this week are directly from you! //cc @SocialFreak @willwood
A weekly email would be fab Greg.
I can’t believe it’s already been over a month! This week’s WeaverTips posts are scheduled and will be all about Previewing your site. Below is a summary of all of the articles so far. Keep the awesome suggestions coming!
Greg
Week 1
Add a link in Stacks
Change how you view the Stacks library
Check for updates in Stacks
Create a new project in RapidWeaver
Create a Partial in Stacks
Cycle between Stacks view mode
Enable upload logging in RapidWeaver
Hide a stack
Lock a stack to prevent editing
Reveal add-ons folder in RapidWeaver
Shows the Stacks library
Toggle the RapidWeaver page inspector in Stacks
Mark a page in RapidWeaver as changed
Mark a RapidWeaver page as unchanged
Week 2
Change the theme in RapidWeaver
Credit RapidWeaver as the software used to generate the website
Don’t credit RapidWeaver as the software used to generate the website
Set the website address in RapidWeaver
Add a new page to your site in RapidWeaver
Week 3
Rename a page in RapidWeaver
Delete a page in RapidWeaver
Disable complex page support in PlusKit
Import Content into the sidebar with pluskit
Rename a partial in Stacks
Make a page a draft in RapidWeaver
Change image format in Stacks
Change image filename in Stacks
Week 4
Change an Image Alt Tag in Stacks
Add an external resource in RapidWeaver
Create a download link in RapidWeaver
Duplicate a RapidWeaver theme
Rename a RapidWeaver theme
Week 5
Add Google Analytics to your RapidWeaver site
Change page from HTML to PHP in RapidWeaver
Change default file extension for site to PHP
Determine what version of RapidWeaver you’re using
Duplicate a page in RapidWeaver
Another week’s worth of posts are scheduled to go, but let me recap the last couple of weeks. Keep the great feedback coming! :slight_smile:
Week 6
Preview your site in multiple web browsers in RapidWeaver
Preview your site in RapidWeaver
Preview your site on mobile browsers
Preview site on an iPad in landscape or portrait mode
Dynamically preview your page for any viewport
Week 7
Determine what version of Stacks you’re running
Determine what version of a specific Stack you are using
Force link to open in a New Window in RapidWeaver
Generate Retina images in Stacks
Export your site locally in RapidWeaver
Well done @barchard - this site has moved quickly from a source of curiosity to a significant RW resource. Really nice work.
Hey Greg-
Is there a missing video here? https://weaver.tips/generate-retina-images-in-stacks
and here?
https://weaver.tips/get-organized-with-stack-groups
I’m getting blank or ? for a lot of the pages where it looks like there should be a video or screenshot?
thanks Lisa
working okay for me. :slight_smile:
(the frame i took happened to have a missing pup in it)
odd. this is what I see in Safari. I just checked Firefox and Chrome… looks fine. I have no extensions in Safari either.
Works for me in Safari. Do you have any extensions installed.
No extensions. First thing I checked :slight_smile:
Try a hard refresh of the page (command + R). See if you can get safari to ignore its cache.
I did both. Refresh and empty cache.
