When i place a new stack, my project go always to the top
Hello, when i place a new stack, my project go always to the top and i must scrolling again to the place where i was working. Is here a solution? Also when i move a stack to a other place, i started again on the top.
Best Regards, Ribse
Same here, very anoying. But known issue and as far as I know no solution yet
It helps if you hide stacks you are not working on.
Check this out…
Hi guys,
This is a pretty common question. So I’ve added an answer here, with lots of details and step-by-step instructions. Feel free to add your own comments/questions: http://cafe.yourhead.com/?qa=153/why-does-stacks-scroll-to-the-top-of-the-page-when-make-changes21
tl;dr: Something on the page is killing the HTML rendering. It’s usually styled text, but HTML/CSS are possibilities too. Use divide and conquer to hunt down he culprit. Fix/Remove it from the page.
Isaiah
Another thing worth checking… if you are using an external font source like, say, google fonts and you have mistakenly requested a font weight that does not actually exist it will behave in a similar manner I.e. Scroll back to the top all the time. Got bitten by that myself,
