You may want to check out Will Woodgate’s ThemeFlood site. All themes – both free and paid – are Bootstrap 4 compatible. They are some of my favorites, both aesthetically and functionally. Will also has lots of great stacks, many of them are free. On top of that, you get one of absolutely best customer support systems.
Both sites have comprehensive information on setting up and using themes, stacks and Bootstrap features. That info alone should be able to get you started, but if you get stuck at any point, Will is very helpful in assisting his customers.
See Link to Rapidweaver Theme kit it has a sample bootstrap project.
You don’t need PHP with themes that I have seen. I use php for my own code and some plugins etc. I also have had to use ASP and Lasso Scripting. It really also depends on what you project requires.
Thanks a lot.
I don´t understand your code. I need how I can declare bootstrap into RapidWeaver editor before exporting de project.
If is complicated I´m not interested in and I will use others frameworks.
Some Rapidweaver themes have built in bootstrap. I use the Affero theme that comes with Rapidweaver. I learned some bootstrap code and added it to my site.
