Would using iphone hotspot to publish site be insane?
I published a clients site. I need to update it quick !
But my cable is down and requires a physical new cable under the house.
If I use hotspot from my ATT iphone (using now) to publish … is that do able / insane / fine /
If you have a decent connection, it will take longer but it should work.
Although some (many?) ISPs prohibit using your own device (at home) as a (web) server.
I use my phone with ATT for a hotspot for a godaddy account that for some reason I cannot log into with my Time Warner cable account and it works fine. Quite fast as well.
Should be fine if you have a good connection. You might go through your data allowance quickly, depending on your cell plan.
