We have the XLoom theme and I set up a Armadillo page.
I tried having the navigation (categories, tags, month) next to the blog, but then this is the result
thanks a lot for your swift solution. That did the trick. I am really not a CSS savy person and it seems Armadillo (read XLoom) makes use of it a lot.
Picking your brains once more: is there a way to make the column wider ? so that text is aligned better. I tried different things but like I said… CSS is not my cup-of-tea… Also tried to change the colors of the blocks also there no luck…
url by the way: www.starobserver.eu (and then go to the blog via the menu)
Oh… and now I think of it. The headlines which are shown on the homepage are put within an ExtraContent area of the XLOOM theme. If I want to alter the way they look, should I use CSS in the page itself .Extrancontent 3 CSS or does this also need to be done via the settings in Armadillo (CSS)?
Thanks a lot for all your help… already thrilled that finally the flex-direction is column
