Thanks @luzule - we’re just working on an update to make Cart compatible with the new SCA requirements firstly and will check this for a future update
As per your question, Checkout is for simple items and subscriptions; Cart is a shopping cart. So they are separate products that depending on the project you can decide which is best. For your situation, Cart is preferable
In fact I’m not sure if that “decimal problem” is just mine or if other users meet the same problem. I’d like to know about it : am i the only “Cart 2” user in this situation ? People : are decimals working on your websites checkout with Cart2 ? Or is it a problem only with my project/configuration ?
Michael ; do you have an idea about when you’ll check this, because I have a client waiting for me now
Thanks !
You did some bespoke work for me a couple of years ago with regard to Stripe. Can you send me a message please as I would like to discuss upgrading the code you did so that it’s SCA compliant.
