Cart 2, bug with Stripe checkout on discounted item - SOLVED
I just discovered that in Cart 2, on a discounted item, the Stripe checkout does not take
off the discount and charges the client the old price. Paypal works correct with the discount.
Can Yuzool themes investigate? @yuzool
Meanwhile I have disabled the Stripe checkout.
Update: Saturday 24-11: Also the discount (amount) for more than 1 item does not seem to do what is expected. It only gives once the discount and does not calculate for the second, third, etc.
@yuzool
Thanks @Jerome
I’ve moved this to the bug tracker:
https://github.com/yuzoolcode/yuzoolthemes-tracking/issues/7
The discount should be working fine in Stripe but will need testing. Are you using the latest version?
Do you mean it only adds the discount to the first item put in the basket?
Hi, I have version 2.3.5 of Cart 2.
The discount is now working; I made a mistake by not putting the discount at
the ‘volume’ box.
But, the Stripe checkout, if you have passed on filling in your name and address, and you
arrive at the credit card screen, Stripe puts back the total amount without the discount to
pay for the customer.
See my page and go to item with the Coconut tooth paste:
https://regadapermaculture.net/getinvolved/stayandlearn/
I see this on your toothpaste item… let me do some testing on my demo page and see if this is a bug
Sending you a DM with a BETA to test @Jerome :slight_smile:
Thank you @Jerome for working on this and we’ve ran through a BETA and it works fine so will be releasing this update very soon for everyone else :slight_smile: in a day or so
Thanks @yuzool for a swift service for solving this bug. Great help!
This is now released to all via email and RW in-app update:
Thanks :heart_eyes:
Only the Item stack automatically updated to 2.3.6, the others stayed at 2.3.5. Is this normal? Thanks!
@bt777 Only that one was updated - but all were changed to 2.3.6 - I’ve just sent you a DM with a download that will fix that :slight_smile:
