I nee the fix also…why has this not been completed in an update these messages are 13 days old already and my problem with mine just stared yesterday and no update on my rapid weaver at all…
where do you paste it to? and where do you have to copy and paste it to looks like there are 2 portions to the stack slider and slider item… i would assume slider item?
I just copied the actual slider item and pasted below and repeated for the number of slides I wanted.
Thanks! i re downloaded and re installed the 50/50 slider and now the + button works, don’t know why i did not get the normal update when you check for updates, but now it works…
Cool. I’ll give that a go tomorrow. I was to busy after buying it to really use it but had a good use case for it!
