Yep, I experienced the same moving from 7.0.3. To 7.0.4. RealMac suggested downloading the entire app from the release notes page (https://www.realmacsoftware.com/rapidweaver/releasenotes/) in case it was a delta update issue. In my case, I downgraded to 7.0.3 and everything’s fine.
Thanks Simon, mine was actually a test project with a simple text stack added, not a work project. In any case, my issue was resolved by switching back to 7.0.3.
I’d recommend not sticking with 7.0.3 if at all possible. It’s got an awful memory issue (and preview/publish will never complete) when working with themes that use certain RapidWeaver features.
Does the performance issue you’re seeing in 7.0.4 improve when switching themes?
I downloaded the full App file again for 7.0.4 and created a new RW project. Opening RW, creating a new project seems markedly slower than 7.0.3.
It’s also taken about 3 minutes just to add a blank stacks page to the blank project. This version just isn’t working for me. If 7.0.3 has an awful memory issue, which version would you suggest as the most stable to use for now?
It seems as if that has happened on first opening a project after applying the update. Subsequent projects went OK as well as the initial project on subsequent opens/saves/reviews and publishes. However, my impression is still that 7.0.4 is significantly slower in all tasks than 7.0.2 (can’t compare to 7.0.3).
