At the end of my Tether with RW7 publishing issues
Hi There
Just wanted to let you know that the publishing in ‘chunks’ worked, although as you warned, I had to restart RW in-between. So not an FTP issue then.
Many thanks!
Glad you got it sorted. I suspect RW has a number of memory leaks, or something, which they will sort over time, hopefully.
(From phone)
This just worked for me. Pulling my hair out since upgrading from RW6 to RW7.04 and could not upload a time sensitive website change.
re: Extended Passive publishing setting
Just found resolution:
Extended Passive publishing setting, instead of Passive.
Passive was set by default and is wrong. Uploading to Dreamweaver right now and it seems to be going smoothly (though slow to FTP in general)
