When using the foundation stack and theme, the background image I set in a column wrapper doesn’t appear in preview.
I’ve tried jpg and png, I’m using the latest version of RapidWeaver and Foundation
Seems to work for me:
Edit Mode:
Preview Mode:
Be sure you have the latest version of the Foundation stacks (1.7.14) and the theme (1.7.4).
Thank You Robert. How do I check the stack and theme version?
Open RapidWeaver.
Hold down the Command key and push the 7 key, this opens the RW addons manager:
In the search window, type the word Foundation. This will bring up a screen like this. You should see the theme version under the Foundation theme.
In the search window, type the work pack. This will bring up a screen like this. You should see the Foundation stack version under the packs.
Robert, I have everything you show except the orange box with the lines (the first item) am I missing something?
Can you post a small demo project file showing this issue that I can take a look at it? Can you show a s screenshot where the background is not working?
Not a problem, I’ll post that. Am I missing something?
I think the problem is that you have no content in your column to make the background visible. Put a sample text stack in there and it’ll show up, I bet…
Yup, you need content for something to show
Yes, It works with a text stack added. Thank you
